CYLINDER HEAD GASKET SACHS 50CC
Verfasst: 25.02.2025 04:55
von HLIAS
Hallo, i am wondering if anyone knows if i must place cylinder head gasket to my sachs 50cc engine. When i loose the cylinder there were no gaket in the head cylinder.
Re: CYLINDER HEAD GASKET SACHS 50CC
Verfasst: 25.02.2025 09:42
there should be a nameplate on the engine, what does it say?
Sachs .xyz....
there are engines without head gasket
example
https://wawa-the-duck.lima-city.de/part ... ame001.htm
https://wawa-the-duck.lima-city.de/parts501/main.htm
https://www.lastboy.de/pdf/emot.pdf
sealing surfaces are planned
https://www.youtube.com/watch?v=4WErGyfrArA
Verfasst: 26.02.2025 06:06
von HLIAS
Hallo, thank you for the informations, yes is the engine type SACHS 501, and as i can see, no gasket needed. just there must be cleaned area.
Verfasst: 26.02.2025 11:48
Verfasst: 27.02.2025 04:22
von HLIAS
Thank you very much for the informations!!!
